hows your suspension setup?
I just recently got my bike back from the shop and it feels a little lower in the back. I thought they may have adjusted the coil in the back and was woundering where you guys have yours set at? I like to get it a little lower if I could but what is the effects of lowering the coil?
RE: hows your suspension setup?
it really depends on how you ride. your luck if you only weight 135 because the stock spring is fine for you. set it on about 4 and see how that works.I would set the rebound and compressio at stock both front and rear.the f4i is perfect for you at stock setting.Let me know how you ride and I will give some pointers.
