MC_spirited |
01-20-2010 09:58 AM |
You can look at the valve cover to get a feel if it has been checked before. Excessive or messy gasket sealer between the head, gasket and cover point to it being removed for atleast a clearance check. I adjusted mine somewhere around 36k. They had been adjusted before. If you do it properly you will feel a noticable change in the engine. By properly I mean measure clearances, adjust clearances, re assemble and SYNC the throttle bodies. Without the sync the engine will not perform as efficenty. If the valves have different clearances that means that air/ fuel intake and exhaust are not the same for each cylinder. By not synching the TB's the intake mixes are not the same, meaning each cylinder performs differently. A properly adjusted and synced engine will idle smoother and have a lower idle.
Feeler guages, Gasket sealer, and a synch device are necessary to do the adjust. You should also have a torque wrench and basic math skills. You can go to a dealer with your valve shims and most will swap your old ones out for what you need to bring them back into spec. If they won't swap them out go somewhere else. I bought a valve shim kit and diddnt even use it. The shims in the hotcam kit are in larger increments than what I needed to make my clearances right.
You can buy what you need to do the maintence for less than a shop charges. Mae sure you have a shop manual, and atleast 3 days to do the service in a well lit clean workarea. If you've never adjusted valves shim under bucket it is a bit intimidating at first. This is not something to rush through (is any maintence?). Take your time, do it right. You'll save money and have better understanding of your machine and greatly improve your mechanical abilities.
