how do you get ur oil filter off?
Old Mar 10, 2008 | 06:56 PM
G3NESYS's Avatar
Default how do you get ur oil filter off?
i think the guy before me tightened his filter/drain bolt a little excessively... seeing as how i had to getan extension arm on my socket to get the drain bolt out... and i cant get my oil filter off for anything... the exhuasts are on the side of it so i cant go from there... i put the wrench in from the bottom, but theres no room to move it back and forth if you do it that way, so i was just wondering how most of you guys actually got it off...
i tried w. my hand as well and i turned so hard my shoulder kinda hurt and it wouldnt budge...
Old Mar 10, 2008 | 07:02 PM
devlzluv's Avatar
Default RE: how do you get ur oil filter off?
lol ya i was gonna say if its your first change the friggin honda robots on steroids put them on there with ungodly strength. try an actual oil filter wrench on her, should pop off with a lil umph, be careful though with the drain bolt, do you have her up on a stand at all see if u can get her a lil higher to put a lil more umph behind it to get under her. plus take your fairings off makes it a lil easier
Old Mar 10, 2008 | 07:06 PM
G3NESYS's Avatar
yea i already got teh drain bolt out and drained it.
theni tried for about 20 min on the filter and couldnt get it so i put the new oil in and went riding, haha.
but yea i realy wanted to try to get the filter off w.o havin to remove fairings so i may just ride w. the new oil/old filter for this season, then do the oil filter/new oil/new spark plugs/new air filter next winter all at once when i have the fairings off.
Old Mar 10, 2008 | 07:39 PM
some guy #2's Avatar
I've used a large set of channel locks before to get the filter off.
Old Mar 10, 2008 | 08:26 PM
slip_'s Avatar
I've hammered a old screw driver I don't use anymore through the end of the filter to get it started quite a few times lol.
Old Mar 10, 2008 | 08:36 PM
dwschultzy's Avatar
Screwdriver through the filter, large channel locks or a good strap wrench. There are some really good filter wrenches on the market that act like a strap wrench.
It might be a little late for this, but I always try to change the oil and filter when the bike is still hot. Ride it around the block or two then let it sit for 5-10 minutes. This usually helps get the o-ring seal on the filter to soften up a bit.
A stubborn filter can be one of the more frustrating things with maintanence.
Old Mar 10, 2008 | 08:39 PM
G3NESYS's Avatar
i let it idle to it warmed up wheni changed it, but it didnt get to full operating temp.
ill try doing it a few minutes after i get done riding tomorro and see if that loosens it up.
Old Mar 10, 2008 | 08:48 PM
slip_'s Avatar
Take it for a little spin to get the parts moving on it, and it'll be more likely to budge. Put some gloves on because it'll be a bit warm between the headers lol. If it comes to it, just take one side of your fairings off to give you a bit more leverage on spinning that sucker.
Old Mar 10, 2008 | 09:03 PM
TBFGhost's Avatar
This is what I use....
http://www.bosstoolsupply.com/index....p;ProdID=11970
Except I foundmine on the inside of a door when I worked in a body shop, I have no idea who left it inside a door shell or how long it was there, but now I use it for my bikes....works GREAT.
Old Mar 10, 2008 | 09:05 PM
jimd2p's Avatar
The one above, or one of these:
http://toolmonger.com/2007/11/08/hot...filter-wrench/
The K&N filters are nice because they have a "nut" welded to the top of them for easy on and off.
