Horn fuse location??
Hello,
I have a 2001 F4i with a non-operational Horn. Is there a fuse located anywhere that might be blown? I also have not been able to check the connections to the horn yet. Anyone have an idea?? My service manual does not list any information about a Horn Fuse.
Thanks in advance!!
~Paul
Thanks in advance!!
~Paul
RE: Horn fuse location??
Try unhooking your battery and hooking the horn directly up to the battery itself, if the horn doesn't sound then the problem is somewhere else. My manual doesn't have the wiring diagram for some reason so I can't look for the fuses on there. You can pull off your front seat and check the fuses at the fuse block there to see if any of them are blown also.
