Hit a log on the highway tonight...need help
well like it says, I hit a log that fell off a truck down in cleveland on the highway and it bounced me up into the air almost as if I was doing a Heart attack (moto trick) and luckily I laned back down on the bike while the back end was losing control, I pulled it off to the side and found that I have a rather large bend on my front rim and a smaller bend on the back one. The bike rides horribly right now. Im wondering if I can have them bent back and if there is anything else that could be ****ed up cus when I go around turns now it trys to pull the bike to the ground and it is very hard to turn at slow speeds. Also how much do new rims cost and is the bike safe to ride to a dealer to have it fixed?
Thanks
Nick
Thanks
Nick
RE: Hit a log on the highway tonight...need help
take pictures be very detailed and close up there are a lot of people here that will try and help. Hard to say from description but your forks and triple clamp might be messed. Sounds like one of the more lucky recoveries I've heard of. Sign up for an ebay account... and join the club. Stay away from dealers for purchasing parts.. you'll pay retail and tax.
scratch that your forks are toast I was trying to be conservative... you'd be fortunate to have not messed your rotors and triple clamp.. worst case too is your frame has been tweeked to a noticable amount. take pictures... brace yourself its gonna hurt.
Not a good idea to ride it -- with a bent rim you could be losing air in the tires. Low air could also cause the handling issues you mentioned. I managed to bend both rims on a bike by hitting a pothole -- it was either the hole or the car coming in my lane. Suspension bottomed out but there was no damage to the forks -- only the wheels and tires. Stock forks have a safety built in to keep you from killing them when bottoming out hard. This doesn't mean your forks are o.k. I don't know how big the log was or how hard you hit it. Your suspension could be toast.
First get in touch with these guys -- Wheel UnBenders They do good work and can save you bunches of $$ on new or e-bay wheels. Second, check your air pressure -- if it's real low then you've got a leak. Don't ride it!! Have it towed.
If you call your insurance company, which isn't a bad idea with more than say $1500 in damage make sure you make it clear you're taking it to a Honda dealer. They will spec out used and nasty **** and still mark it up for retail with their own network of repair shops. They could take your bent fork off and put a little less bent forks right back on.
