Help with Rear Brake
Gents,
Looking for some ideas or past experinces that may help. Ill try and be as to the point as possible.
My rear brake is completley useless. I removed the system for some maintenance to other areas of the bike not the brake system. After re-installing everything bleeding the system etc the rear brake might as well not be there. The thing I notice is the rear caliper flexing excessivley under load. By flexing I mean when pressing the pedal the whole caliper moves from left to right. Ive checked and re-checked all my torque values, cleaned the threads, put loc-tite etc. Everything I can think of but still the caliper moves under load. I know there is supposed to be some movement but I think all my braking energy is being spent when the caliper moves and leaves nothing left to slow the rotor.
Any ideas on where to go from here would be appreciated. Thank You
The caliper is supposed to 'float' on the hanger-pins. That allows it to self-center on
the disc, compensating for pad wear. My guess is either, pedal not adjusted properly,
or air in the line. The air can come from either, improper/insufficent bleeding or if any
of the banjo bolts were loosened/removed failing to replace the crush-rings (allowing
air around them from improper seal).
Ern
Ern
I know it's supposed to float so as not to drag, but what I am seeing seems excessive in comparison to what I remember from before. I have bleed the brakes numerous times, both the traditional pump by hand method and using a friends vacuum bleeder. I'm not completely ruling out air in the lines but I'm rather confident I got it all.
I'm not a wheelie guy but I have always liked using my rear brake for low speed stuff, after doing the majority of braking with the front Ill cover the last few feet say for instance to a stop sign with the rear. I also start off on a lot of hills so I hold with the rear so I don't roll back and have my hand free for throttle.
I will have to look at the manual and see if I overlooked something when putting it back together.
Any chance the caliper bracket could be stripped out? Anyone seen this?
Hayden06F4i
06-17-2008 09:50 AM
