HELP PLEASE
Old Aug 11, 2006 | 10:35 PM
e3gordon's Avatar
Default HELP PLEASE
I went outside to start my bike, did so and after the high idle came down (normally when the temp readout turns on to 100 or so) nothing happened.
Basically My temp readout says nothing but the two dahes(--) !!!!!
Anyway, I took it for a ride and got it good and warmed up (I know) and still nothing only --. So my quesion is do you have any idea what it could be? A sensor?
Old Aug 12, 2006 | 12:01 AM
dwhite645's Avatar
Default RE: digital Temperature gauge
Yeah, my guess would be the sensor. I believe, but not 100% sure, that it's on the left hand side of the radiator. Check the connections for it too, might have just come loose.
Old Aug 12, 2006 | 12:38 AM
ejohn's Avatar
what are saying that it never idled down?
Old Aug 12, 2006 | 02:56 PM
e3gordon's Avatar
yeah i never got a temp reading on the gauge.
I'll check the connection. Thanks dwhite
Old Aug 12, 2006 | 02:59 PM
ejohn's Avatar
i think that happen once to me after i washed it. just a glitch.
Old Aug 12, 2006 | 05:15 PM
e3gordon's Avatar
I jsust checked the shop manual and it shows the temperature gauge sensor under the throtle body.
ECT Temp gauge they call it
Old Aug 13, 2006 | 03:56 AM
jimd2p's Avatar
Does this temp sensor send the signal to the guage or the ECU? I work on cars for a living and obviously these are two different worlds, but on a car you will generally find one sensor for the guage and and one for the computer to tell it how to adjust the fuel mixture based on the coolant temp. Often times the temp sensor for the guage is mounted in the radiator or near the thermostat neck, while the ECT for the computer is in the head.
Again I may be talking out my *** for a motorcycle, but this is how it works on a car. I am trying to get in to the Honda site to check the shop manual and I am having trouble.
Old Aug 13, 2006 | 04:55 AM
ruizs's Avatar
Default RE: HELP PLEASE
The sensor that sends the temp to your gauges is right under the thermostat - you'll need to remove the tank, airbox, and throttle body to get to it. If you have a multi-tester, you can probably check it for its resistance rating, its listed in the clymer manual. And yes, you have the right one picked on the parts site.
