Help my F4i won't start
My battery wasn't so good at holding a charge before being stored all winter. I know I needed a new one, but am waiting till I move back from Germany to the US in a couple weeks. My bike has been winterized(fuel saver, oil change, battery tender, on some stands) since October. I just broke it out to tried and start it. The battery doesn't have enough juice to crank it, but I tried to jump it off a car battery(car not running) and I still can't get it to crank. The fuel injection light goes on and off and I'm not getting any error messages before I try and crank it.
If the battery is toast, should the bike run if you jump it. If so any suggestions on how to fire her up before I put her on a boat for a couple months. I would have to drain the gas if I can't get it fired up instead of getting one last ride before the move.
Thanks
Thanks
Stop, stop...stop! Do not jump the bike with a car battery. Take your bike battery out, swing by a shop where they can test it, if its bad get a new one and problem solve.
What would possess you to jump your bike with a car battery? You're bikes a 12V and your car battery isn't? Unless you wanna risk damage to the wiring harness, your ecu, and electrical components, STOP jumping bikes with cars! Are you trying to make a bad problem worse???
I've jumped my bike plenty of times with my car battery. Both are 12V. The only difference is the current output and capacity. As long as you keep the car engine off, there isn't a single thing that can go wrong if you jump it right....
JayBoCC2
06-23-2009 10:23 PM
