Help me out please, stranded on the road! Bike not starting
So I started my bike getting ready to take off, idling. Then the bike just dies. When I turn the key, absolutely nothing happens. No lights come on, fuel doesn't prime, nothing. Like the bike doesn't even know I'm turning the key. I tried jumping it. The battery has juice. All fuses are all good. Could it be the ignition? I had the typical problem with the starter before, and had to resolder the wiring. But even then, the bike would respond when I turned the key. Any ideas would help me out please!
There is a large connector in the wiring system that likes to cause problems when its wet out....either way you probably aren't going to be fixing it on the side of the road :(
Check 20A main fuse? that's not in the fuse box.
Originally Posted by boredandstroked
(Post 1273749)
tilt sensor??
Originally Posted by AntP1987
(Post 1273810)
Where is this connector you're talking about?
