HELP - head n tail lights stopped working
Took her for MOT on Wednesday and passed no problems, even with a man from VOSA visiting and watching over it lol
So I ride home and tuck her away for a few nights. Then whilst moving her in and out of the garage this weekend, I noticed the lights aren't coming on
Brake light and indicators are all fine, but head and tail lights aren't coming on at all, not even on full beam.
Anybody out there seen this before?
Only had her a few months and not really found my way around any of the electrics and mechanics just yet.
P.S- 10A Headlight fuse beneath the seat looks fine btw.
Really gratefull of any suggestions/ideas!?
Make sure your starter switch isnt stuck halfway in.
F4i's have notorious problems with solder joints comming loose in the starter switch itself, disabling your headlights. It's an easy fix with a steady hand.
edit: you say you found a headlight/brakelight switch? im curious....
Be sure that you don't just have a loose /dirty connector, as well. Any auto store sells
electrical contact cleaner, try pulling all the connectors and hosing them. Then,
re-connect and see if the problem goes away.
While you're at the store, pick up some di-electric grease. Pack that into the connections before you call it quits. That will protect and ensure no moisture
penetrates from then on.
Ern
Ern
Will Blanton
02-02-2021 01:03 PM
