helmet locks/holders...
I saw a bunch of bikes at bike week here in NH today with their helmets hanging from the side of the bike right next to the rear seat. Were they locks, or holders or something? I have been looking online for a while, but i can't figure out how it works. Do you guys have this? where does it mount?
You have an f4 correct? Depends on what year. I have the split seat (03) and on mine you remove the seat. There is a cross bar in the frame. If you follow that to either side there are metal L brackets pointing towards the center of the seat. You hook the helmet d-ring to them put the seat back on and now you've got a passenger helmet so you can get a Hooters girl in uniform on the back of your bike.
It's not the plastic part that's hanging on the actual seat. It's the metal L bracket in the "trunk" itself. So you remove the seat, look in the "trunk", find the little bracket, hook one of the rings on the chin strap of the helmet, put the seat back on. You're ready to go.
Notice where the stainless steel bolts/screws (most use for a bungee connection) bolt through the rear cowl plastic and into the sub-frame? Now when you take the rear seat off you'll see the "cross-bar" that was mentioned before - this is also where those two bolts connect. Adjacent to this bolt, there will be a small bracket welded to the top - kinda looks like an "L" and a "U" on it's side. Slip the D-ring into this "U" and that's how you hang your lid.
Sorry I don't have any pics, but it's really quite easy. Should be in the owner's manual too... if you have one!
