Heated grips relay wiring question
Old 12-16-2014, 04:46 PM
Default Heated grips relay wiring question
Hi all, I have installed some heated grip to make my commute a bit more comfortable today
at the moment i wired them directly to the battery however i have read up about it and brought a standard 4 pin relay(85,86,87,30) to wire it so that it won't be left on accidentally.
the question is where is the best place for the relay and what wire do you guys use? I have read up here but it isn't really clear on where is the best/easiest place tap from, ignition?headlight? others? and how did you guys do it
Many thanks
Kit
Old 12-16-2014, 06:36 PM
sjona2011's Avatar
i had heated grips on my f3, i however did not use a relay, just wired power straight from the rear tail light(running light). But you can wire the coil for the relay to anywhere that gets switched on from the ignition, then simply run a power wire from the battery, to the NO contact on the relay, then to the grips.
Old 12-16-2014, 09:34 PM
June 2013 ROTM
Use a switch wire like the license plate light. I put a drawing in this thread:
https://cbrforum.com/forum/general-t...600-f3-144038/
Old 12-17-2014, 06:03 AM
Thanks, you remind me that i have my number plate light wires that its just blanked off, goona just use that;
silly question just to be sure: on the ground wires it is the same as connect it back to black on battery?
Old 12-17-2014, 09:26 AM
June 2013 ROTM
Correct. Rather than running wires back to the battery, you can just ground to a part of the frame. Check to make sure your desired grounding spot is indeed a ground by using a multimeter to check the resistance between the point and the negative battery terminal. Closer to 0 ohms the better.
Old 12-26-2014, 11:35 PM
Retired Super Moderator
Something else to keep in mind. On the Hot wire you run from the battery, try to put your fuse as close to the battery terminal as you can. You don't want a power lead running around your bike that does't have a fuse protecting it.
Timmy_Jones
10-26-2010 07:48 PM
partytime
11-06-2008 07:52 PM
FfourI600
10-24-2008 02:38 PM
paulpaul
04-26-2007 11:33 PM
llhank
11-07-2006 03:02 PM
Quick Reply: Heated grips relay wiring question
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
