Headlight Problem
Old Jun 8, 2008 | 01:29 PM
Twiztid CBR's Avatar
Default Headlight Problem
Both of my headlights went out so I looked at the fuses and they were fine so I tried to turn the brights on and the light on the dash wouldn't even light up. So I changed both of the headlights and checked the fuses again still nothing. Please Help!!!!!!!!!!!!
Old Jun 8, 2008 | 02:22 PM
whtan20's Avatar
Default RE: Headlight Problem
Fuel primes? Engine turns on?
Old Jun 8, 2008 | 07:56 PM
y0ukeun's Avatar
my f4i had this same problem right before i sold it....sorry tho i dono how to fix it.
Old Jun 9, 2008 | 02:06 AM
Bike starts fine just the lights won't turn on or the brights
s1lVa's Avatar
Im having the exact same problem! Both my lights stopped working a few weeks ago. Its not the fuse, nor the bulbs
when i ride hard, sometimes the lights comes back, bit they go away after a while.
I have no clue whats wrong. Can anyone experienced help?
Thank you.
Old Jun 9, 2008 | 04:23 AM
Aken's Avatar
July 2008 ROTM
Check your wiring harness and plugs for frayed wires, bent prongs or loose / fallen out wires.
Old Jun 9, 2008 | 12:18 PM
s1lVa's Avatar
Atleast I managed to fix the problem!
The fusebox wire to the headlights were loose on the backside of the fusebox... had to be a lot of heat there becuse a tiny plastic bit had meltet.
Old Jun 9, 2008 | 01:15 PM
I checked the wires under the seat by the harness I didn't find any loose wires does anyone know what I should be looking for?
Old Jun 9, 2008 | 02:06 PM
Aken's Avatar
July 2008 ROTM
Um, perhaps the large amount of wire between the fuse box and headlight? Specifically the gray plug that connects your headlight to the main harness.
Old Jun 9, 2008 | 04:10 PM
Tahoe SC's Avatar
check for a signal from the harness to the bulb socket for continuity with a multi-meter. if you have one then move on to the next stretch of wires.
cajun rider
Mar 22, 2012 07:37 PM
rnora1
Jun 11, 2009 10:28 PM
bottlebaby
Jun 4, 2009 09:38 PM
josemiguel
Oct 20, 2007 09:06 PM
