Headlight block off plate?
RE: Headlight block off plate?
its called a upper race fairing. you need to get a race fairing set if you want to go on the track.
or a cheaper way is to put masking tape on the headlight.
i have never heard or seen anyone take out a headlight lense and fill it in, you might be on to something but more likely you are on something
there isanoem replacement upper fairings with the headlightspace filled in (check ebay) but if you unplug the headlight wiring harness you'll need to cross off the BAS. I will say that if you crash hard enough for the headlights to get damaged, the cost of the headlights will be by far the least of your worries.
