Have to drain tank if not really removing it?
I know that sounds like a silly title but here is what I need to do...brought my F4i in to have the CCTL replaced....it looks like they may have needed to take the tank off to do it as there is ano a gap on the right side between the frame and the tank and that little rubber "curtain" was bunched up a bit towards front of bike
I'd like to center the tank so it sits even and get that curtain pulled back and hoping I don't have to totally remove the tank
Hard to remove the tank without draining it..if they did move it they didn't drain it[&:]
Any hints or tips on this?
Goose
Goose
RE: Have to drain tank if not really removing it?
Now that I look at the tutorial over on CBRworld it looks like the fairing gets removed...not the tank....ok..that should make thinggs a bit easier without having to mess with the tank
Ok who has taken off the right upper fairing lol
Goose
Goose
The daylight shows a lot more..they must have taken off the plastic piece that sits up and to the right of the tank under the right grip(above air intake) and that didn't get put back together correctly...there is a clip under the windscreen that plastic piece should slip behind....the tech didn't do it and it is sitting on the outside of the clip creating a big gap between the fairing and that piece
seriously wtf..first day out of tech school? Sort of pissed...fix myself or bring it back and make them do it? Not a small dealer either...Naults is pretty big in this area
Goose
Goose
I sort of doubt your tank is on crooked. They're retardedly simple to line up. Either it's aligned perfectly or it's not on the bike.
Sounds more like your plastics are out of place. I've messed up putting my plastics back on plenty of times. It's tricky to get everything aligned and snapped together (no excuse for a tech though). If it's really just the plastic that's out of place, just start unscrewing things with a 5mm hex key- there's one in your toolkit. I can't imagine it taking longer than 5 minutes even if you've never turned a screwdriver before.
Plus, it's good to know how to take your plastics off in case anything goes wrong with your bike. It's like popping the hood of your car. Save yourself the $100 diagnostic fee at the stealership, and most of the time you can just fix the problem yourself.
Yeah..I actually went out on break and fixed the parts that were popped out...took like 2 minutes to do..
Still pisses me off that they couldn't put stuff back together right though but what the heck...don't sweat the small stuff I guess
Goose
Goose
ORIGINAL: whtan20
Not that hard, siphon the gas out (most likely the only way) and remove the fuel pump, wallah the tank comes right off
ORIGINAL: Jaybird180
Be careful when removing the pump. Get a new gasket and do NOT crank it down too tight. Use the procedure and specs in the manual. You don't want to experience what I went through.
ORIGINAL: whtan20
