Gauge cluster comes on ONLY when using front brakes
Ok so everything has been fine for a while but just the other day as I pulled in to work I put my kickstand down and usually it shuts the bike off, I simultaneously let go of clutch and it stalls no big deal I come back to ride home and the gauge cluster is showing nothing but as soon as I pull the front brake in everything lights up..... any ideas? Thanks in advance
i'm not too sure, but mine is doing something similar. seems like mine is the front brakes or doing 60mph or a combination of both
Is this only when your going that hitting the brakes gets the gauges to work or does it also work standing still?
on mine the speed show 0 all of the time unless it's actually showing the speed, when the key is turned on it does the max out deal and then drops back down to 0
boostless -- your problem sounds like the speed sensor in the tranny or the cable. Something loose or maybe a little corrosion.
Originally Posted by chainstretcher
(Post 830123)
Originally Posted by Bskinn77
(Post 830046)
This was 3 1/2 years ago...
Originally Posted by 74demon
(Post 1209899)
