Gas in the exaust
im gettin gas pouring into my exaust on my stunt bike guy i got it from told me the fpr was prob bad so i ordered a new one
could there be anything else wrong i should look at? |
that would be the fpr, if gas is in the exhaust, just get it done and u should be good
cool thanks alot man
put the fpr in and a new battery .. works great now .. low rpm are a little rusty but it sat up for a bit so im gunan cleant he fuel system out
with the fpr being bad the plugs prolly got fouled. sry to say it, but u may try pulling them and seeing how they look
yep what Van said. Replace the plugs, also run half a can of seafoam through the tank. it'll clean the buildup from what they call gasoline these days.
aight ill check the plugs in the next few days only thing it does now is once i start it i gotat give it gas for like 30 secs or it will die once the idle kicks in i can let off.. after that the bike ran fine
ya sounds like gummy injection system. run the seafoam through it.
ya i figured that they need 2 be cleaned thanks
I'd also change your oil.
