Garmin GPS Motorcycle Mount.
Does anyone have a GPS Mount that fits anyhwere on the f4i, theres no actual handlebar exposed to put a mount on so idk if anyone has a threaded mount, so if anyone has one of these and can tell me where to purchase one cuz i cant find one and i need one cuz i just moved to a new area and would like to have it
GPS Mount for F4i
Since I work for Clarion, I test a lot of different PND (Portable Navigation Device) and I ride my bike everyday I also need a place to mount the PND. I am currently using our EZD580 Portable Navigation.
What I did was used the bracket that came with the PND and made four 1/8" holes that would line up with a Pana-Vise mounting post. I then used a T-Nut inside of the Pana-Vise post. Then I used the OEM plastic yoke cover and drilled a hole in the middle of it and used a bolt with a washer to connect it to the T-Nut that is in the Pana-Vise post. Once I had the correct angle to see the screen, I tightened up the hex bolts and mounted the PND in the yoke.
I will take some pictures of the finished project and post them for you.I have attached a picture of the left side of my bike and you can kind of see the PND mount. I will get better pictures for you.
If you email me directly, I will send you the step by step instructions with pictures that I will make for you in excel. If you also need the parts, I will check to see that I have in my garage.
