Galfer front lines
RE: Galfer front lines
the stock bolts are harden, the galfer ones aren't..so the torque specs are like much less, something like from 22 stock to 12 ft. lbs...
no you're not supposed to use the stock crush washers, but take a look at them, if they aren't messed up, they can be reused...i have reused mines and so have many others with no problems. how do you know if there's a problem? when your lines start to leak! so it's a chance you take...but you can just get them from the dealers...for real cheap.
ORIGINAL: stuntn_r6
well i thought that stock there is only one line that connects to the master and with the galfer you have 2 lines connecting to it...i need to look at the bike...
Get ahold of J.T. @ chromewhore.com - he hooked me up when I bought my set.
