Fuel tank torque settings
Old 11-13-2017, 05:15 AM
CaBaRet's Avatar
Yes , could be onto something there matey
  #32
Old 11-14-2017, 02:15 AM
Finchy's Avatar
Originally Posted by Johnnyr1red
I think I know what it is, the pipe on my tank points to the back of the bike but in the image below, it looks like it should point forward.
Someone has removed the whole fuel connection thing and put it on the wrong way. Maybe when it was sprayed it was done then.
Mine is the wrong way isn't it
Definitely the wrong way round, Jonny mate. Not just that hose though. Looks like the whole assembly is backwards. The fuel return hose with the L shaped pipe should be to the front of the bike. The banjo bolt etc should be to the back of the bike with the main fuel hose running forwards and straight (no longer bent around).
Hope this solves the prob, mate.
  #33
Old 11-14-2017, 02:18 AM
Johnnyr1red's Avatar
What a nightmare, I bet the guy that sprayed the tank took the assembly off when he was repairing the dent in it.
It was horrendous to get it back on as everything was so tight...now I know why ffs.
Cheers lads
  #34
Old 11-14-2017, 02:23 AM
Just a thought, do I need to replace the gasket when I remove the assembly?
  #35
Old 11-14-2017, 03:53 AM
Finchy's Avatar
Yeah, most likely was. Well, at least now you know what's going on.
Yep, new packing every time.
Have you got a service manual, Johnny?
  #36
Old 11-14-2017, 04:19 AM
Just ordered one, £11 so it's nothing really.
I have the PDF manual kindly supplied by CaBaRet, looks a pretty easy job once I get the tank off, worst part will be draining it again.
I'm pleased I've found the issue though, I knew it didn't look right.
  #37
Old 11-15-2017, 04:42 AM
Finchy's Avatar
Yeah, shouldn't cause too much trouble. You'll find the tightening sequence and torque level in your service manual there. Page 5-54.
  #38
Old 11-15-2017, 05:03 AM
cheers mate
  #39
Old 11-16-2017, 08:35 AM
Finchy's Avatar
cheers mate
No problems at all, mate. Let us know if it fixes the problem.
  #40
Old 11-18-2017, 10:04 AM
Absolutely fed up, turned the assembly around, put a new gasket in and it now bloody leaks. It is leaking out of the gasket, not just dripping, pouring.
Took it off and reseated it a few times and still leaks. It looks like it is sitting perfectly.
Quick Reply: Fuel tank torque settings
