600RR Hand Levers on an F4i
Old 12-03-2008, 12:01 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Default 600RR Hand Levers on an F4i
Does anyone know if 600RR levers (Brake/clutch) will fit & workon a F4i.
Old 12-03-2008, 06:35 AM
CBR Time's Avatar
Default RE: 600RR Hand Levers on an F4i
believe they do? not 100% though. Someone must know here?
Old 12-03-2008, 02:23 PM
Aken's Avatar
July 2008 ROTM
Is there a reason you want to use RR levers? There's no added performance or functionality with them. Unless you just found a good deal on them...
Old 12-03-2008, 06:57 PM
Incognito's Avatar
Well, not only do they look better, but I'd like my clutch lever a little closer to my fingers. I've even thought about buying a stock lever and bending it back a little. On e-Bay, levers can be found dirt cheap.
VS.
Old 12-03-2008, 08:48 PM
Stephens's Avatar
The carbon fiber ones will work. I had some of them once til they broke on me when my bike fell over on soft asphalt. They break really easy, so I went back to the chrome metal ones.
Old 12-03-2008, 10:37 PM
those cabron fiber ones break easy huh? i was looking at them just now and thought of getting them. i am worried one of them would break while driving. that would suck. how did they feel, did they feel soft and just plain cheap? i need to replace my brake lever, it's all messed up.
Old 12-04-2008, 12:21 AM
Incognito's Avatar
The carbon fiber ones pictured above are not real CF ~ not at $16 dollars per set.The black ones are 600RR and the CF are F4i. They're put up just for demonstrative reasons.They look pretty damn similar to me. I guess I'll just buy apair and see how they fit. It's just that I don't want to spend $75+ dollars a piece on a nice adjustable set (just yet).
Old 12-04-2008, 01:20 AM
oodie's Avatar
February 2009 ROTM
Just looked at both my bikes and yea i they will work because the Master clyinder is excatly the same. Clutch i dont see a problem either.
Old 12-04-2008, 01:38 AM
Incognito's Avatar
OODIE ~ You the man. Thanks
I'll post pics when they're on.
Old 12-04-2008, 09:39 AM
some guy #2's Avatar
05+ RR's have different MC's but if the levers fit on a 03-04 RR then they should work.
Quick Reply: 600RR Hand Levers on an F4i
