Fuel injection problem
#21
I'm not being a d**k. I stated i was confused. you told me to read properly. I told you I did, but you wrote it in a confusing manner. What about this was rude?
If you don't have enough pressure, either a line is kinked/bent wrong, or the pump is bad and not pushing hard enough. You said flow rate was correct, so that leaves the pump.
#22
We go to an extreme to keep nastiness off this forum. Maybe you should hang around a bit more before before throwing out such accusations.
#24
