Fuel injection problem
Hi Guys I'm hoping someone can help, my bike will not start, I have just replaced the engine as the last one blew up.
I have installed it correctly and all electrical stuff is installed correctly
It turns over fine.
It runs fine with easy start so spark and compression is ok.
There are no fault codes on the injection system.
The pump is working fine, fuel flow rate through injector rail is fine so fuel is getting to injectors.
power is getting to injectors and the resistance through the injectors is within the readings from the manual.
so I don't know why they are not spraying the fuel?
Any ideas?
It turns over fine.
Any ideas?
Did you check for fuel pressure at the rail? Fuel injectors are just open/close valves with a tip that gives it a spray pattern.
