Fuel guage doesnt reset after fillup
Got a weird problem with my fuel gauge, it wont reset its self after i fill it. But if i un-plug the connector for the display it will work n go into reserve like it should but then again once i fill it wont reset and the display still flashes empty. Doesn't matter how long I wait it just stays flashing
Any thoughts? I would have figured the same switch that would activate the reserve would also reset it once the fuel pasted that sensor. |
I have this exact problem on my gauges. This and my tacto just completely died. But i did find a temp solution for the fuel gauge but you will have to sacrifice your clock and trip meter (although total mileages aren't touched). I ended up having to pull the fuel gauge fuse out so it resets every time the bike is started, aka after refueling. I hope we can find a solution soon, although i would much rather have my tacto back.......
I have an 02 and my fuel gauge doesn't even work i don't know if the problem is related but i really wish i knew
Originally Posted by clepies
(Post 1095581)
also, after you fill up it won't stop flashing immediately. IT takes a few minutes of riding first. |
reserve gauge stays on for 90 seconds after the kickstand is up, if its put down before 90 seconds it waits another 90 after its back up.
