Front vs Rear Tread Life?
Why change a tire that isen't worn out? Replace each tire as nessacary. The bike isen't going to do anything better with 2 new tires vs just replacing the one worn one. Hell I've even run different tires before without ill effects [pilot sport front, power rear, then power 2ct front with pilot rear, right now its a pilot pure front and power 2ct rear]
because he already has a new set, and if one is already bald, and the other is already more than half way used, why not put a NEW one on each end, and start over?? if you replace them at the same time, you don't run into a list like yours...with 3 different tires on at different times.
adam833
08-13-2007 02:41 AM
