Front end facts and figures needed
Hi Guys
I’m planning cbr600f4/f4i front end swap for my Honda 919 (aka Hornet900) Few sources claim the conversion is bolt on, but still, before I started bidding, some info about F4/F4i would give me peace of mind. I know the forks, wheels and rotors are different in F4 and F4i, but as far as I read, the whole set (forks+wheel+rotors) is interchangeable. So would anyone be that kind to share the following numbers -What is the length of F4/F4i forks from spindle centre to top? I need this to be sure the steering geometry won’t change after conversion -What is the stretch between forks centres? I measured 204mm (8.031 inch) on 919, so it should be the same, hopefully -What is the stretch between rotors (provided they are not too worn)? I measured 132mm (5.196 inch) from the inside of mines, is it the same with F4/F4i? Thank you all in advance Vasko |
