Frame Slider Bolts
Frame Slider Bolts
I just bought a used 02 CBR 600 f4i. The previous owner laid it down at low speed on the right side slight dammage to the exhaust. Luckily he had frame sliders installed when he laid it down. When i got it home i noticed the frame slider on the right side was loose. When i took it off I noticed some the the threads were striped. It looks like too short of a bolt was used when installing this frame slider. I have been looking for a longer bolt but cant seem to find one anywhere. I need a M10 x 80mm x 1.25 does anyone know where I could get one?
RE: Frame Slider Bolts
Hardware store?
BTW, DO NOT get Grade 8 (or metric equiv.)
You don't want a high strength fastener because in the event of a high speed laydown you want the slider to be able to shear off and not jack up your frame or engine case. Rash on the frame is better than a cracked off engine mount.
If you don't have a Lowes or Home Depot, (i can't imagine that) then look in the phone book for a nut&bolt supply.
ORIGINAL: dis3as3d
Ive gone to Lows and even a local machine shop, they dont have them and if I want to order them. There is a minimum order of 100 bolts. The problem is that it is a metric bolt and an odd size.
Where do you get one locally? Im in the greater Seattle area and have just about every flavor of shop around but still cant find this bolt.
ORIGINAL: Blackdog F4i
I was going to say I am sure I could get one locally and ship it to you, but it would cost more on shipping than the bolt is worth.
