Forks for the '02 F4i
Do not use your bars as a guide to see if everything is straight, square up you top triple tree as much as possible and then look at your front wheel to see if it looks straight, it could very well be as simple as your bars being off. Did you hit anythong with the front tire, or did your bars touch the ground? It's sounds like it could be a serious bend you should be able to see, POP your bars off and look down the tubes if its a major bend you'll see it, otherwise take it in to have a run out done.
jfunkRR
04-30-2008 09:23 AM
