fork / alignment questions
Okay, so my forks were bent. I knew this because the tires wore off center, the front axel wouldn't slide in very easy, and when I let go of the handlebars it would drift to the right.
So... I got new forks and installed them today. I took it for a test ride and now it drifts off to the left when I let go. I couldn't help but find this funny but I have a few questions. I'm thinking that maybe the bike is now drifting left because the front tire was worn so much with the bike wanting to go right for so long... what do you think? And I'm thinking this will eventually correct itself or when I get a new front tire. |
Originally Posted by DBEAU
(Post 828957)
Yes, the front tire is worn quite a bit more on one side. The forks are also at equal length in the triples.
if the tire is visually worn i'd replace it first and see where you stand
after that i'd check the triple clamp to steering stem alignment |
Originally Posted by bwayers
(Post 829585)
Update: So I finally put a new tire on and she rides right as rain! I'm pretty excited about it because ever since i bought the dang thing it had bent forks and drove crooked.
Anyway, I'm quite astonished at how much of a difference an oddly worn front tire can make. Not to mention how much of a diffrence you feel when you put new tires on. You almost forget what you're missing after you put a few thousand on a tire. |
(Post 837932)
Ohhh yea, the tires make a huge difference, it's can almost be compared to a brand new bike. When I bought mine, she had bald as hell tires. Those tires caused me to meet the ground once. A car made a quick stop in front of me, I didn't have the handlebars straight... split of a second, I'm looking at my bike sliding on the ground. I simply locked the front wheel.
So, good tires is a must on any bikes! |
