flushmount Turn signal question
#23
#25
#26
worst part is, i am a flippin computer engineer and have done website design and coding for years...arghh...whatever...
as to the install...if you do the running lights mod, it takes longer...the only probably i had was that the OEM stalk signals were really tight....the bolt took awhile to loosen up and break free....other than that...the install is cake....
but like i said if you do the running light mod....you have to wire in two diodes per side...it's easy enough except that diodes don't like to be soldered...at least the ones i had didn't, plus i am a perfectionist when it comes to an electrical install so i shrinked wrapped everything to make sure it was clean....the prep for just the wiring took me a bit, but the actual light install is super easy...
just take off the front fairing...that whole assembly is all that you need and wire em up...
#27
#28
really it's not that bad...just a little more time...check out the "How-To" forum and there is full instructions on how to do it, or i can even give you tips...i think it would be a shame to lose the running lights...plus i like how they look when they are on anyways....
#29
well when i buy them ill definatly hit you up for some info. gonna get them in like 3 weeks cause right now im buying a a 01-03 tail faring and the 2 seats and just bought a subframe to do the dual seat conversion. i found a good deal on a 02 yellow tail fairing the only problem is the yellows dont match the yellow on my 06
#30
