Flasher relay suggestion
RE: Flasher relay suggestion
I insalled the VFX universal flasher rely in my 06. I'm happy with it. It was about 20 bucks but I'm in Canada where a case of beer is a 2nd mortgage. It is plug and play, meaning it uses the existing relay's connector. The only problem is that you have to remove the upper fairing to get at the relay as it is located between the head lights. If you are at all mechanically inclined it isn't too difficult.
Hope I help a little
I have something called a Trick Flasher. It's plug and play to the existing wires in place of the stock relay. Got it for $40 (yeah it's high but has several flash options) and I got it along with the Protons. I used it with the stock rear and led front for a few months, then bought the clear alternatives tail. I like it.
muckdawg24
09-17-2007 12:13 PM
