Flame, popping and gas smell
I have read many posts for these conditions. I believe I have a bad Fuel Pressure Regulator. My bike has all 3 symptoms. My bike did this last year before I tore it apart for the winter and replaced some things. It is still doing it. I replaced the plugs, filter, remapped my pc3 and it still happens. I think the FPR would be my next thing to replace. Whats your guy's opinion and is there anything else I am missing. The bike is a 2003 cali model, 32,000 miles, power commander, K&N (brand new), spark plugs (brand new), M4 high mount exhaust.
Thanks in advance for your help
That is exactly what my bike was doing. The little catalytic converter was glowing red on the outside. Not good. It kinda gets worse, the longer you let it go. I replaced the FPR and everything was groovy. I did all the stuff you did too, power commander remap, new plugs, new coil packs. All did nothing.
Well, I dont really know if all the bikes have it. It is a bulge in the stock pipe, right in front of the muffler. Anyway, it is not removable. It is part of the exhaust. You can simply put on a slip on, and then you are all good. The fuel pressure reg? I would say, 2 hours or less. Fuel can get all over, so you have to be a little careful, but it could also take less time if you are handy with tools. It is not tough.
Just prop up the tank and open the fuel cap to vent the tank and minimize gas leakage. No need to remove anything else, shove lots of rags under it before you start to un bolt, because leaking gas is part of the process. 8mm bolts i think?
Make sure you are using a NEW O-ring and it's seated correctly on the new FPR. Have a ball point pen ready to shove/plug up the fuel line once you take it off the FPR or you'll have quite a bit of gas pouring out. Takes 20 mins if
your handy.
How to: replace FPR Writeup
your handy.
