finished cutting pipe (pics)
So I cut 6 1/2" out of the trs yesterday and everything went pretty good. I followed Sick's tutorial for the most part. I don't understand though why he did it in two cuts because it can be done in one. Cutting is the toughest part so one less cut is nice. Drilling the new holes through the stainless steel for the rivets was pretty much impossible with the regular drill bit so I bought a 3/16" cobalt bit and it was butter. Definitely worth the $8. Anyway heres some pics
I used a slot screw driver to bend the edges a bit after I drilled out the rivets just make the cap slide off easier. It was still pretty tough though
but yea dude it should sound good make sure and let us know
Pipe sounds unreal! Only rev'ed to 7k but still significantly more throaty then pre cut. Definitely worth the time to do it.
Thanks man. How much did you take out of yours? And ya i'd probably be way too lazy to repeat that whole process for another inch or two haha
