FI light? 2 blinks
so my FI light came on today when i was riding...when the the key is on it blinks twice. does anyone know what this code is?
thanks |
According to the service manual, 2 blinks at ignition is faulty MAP sensor and/or loose connection of the MAP sensor hose.
However, check the length of the blinks- a 1.3 second blink is equal to 10 blinks which would give it a different code. If they're both the same length and a fast blink, then it's just what I typed above from the manual. |
1 Attachment(s)
yep map sensor.
Attachment 62633 check the vacuum hose and make sure she's snug. dielectric grease the pins to help increase electrical conductivity. |
had the same problem. i took the tank off and noticed the thin hose was disconnected from the MAP sensor. hooked it up, turned my f4i back on and the light disappeared.
great thanks ill check it out
Where is the Map sensor located? I have a 2008 600RR with this FI error. Any help on location would be great!
Originally Posted by FLYOU
(Post 794793)
yep map sensor.
Originally Posted by phia_thao
(Post 1356368)
(Post 1356368)
- reference 5v power supply wire - ground wire - signal wire to ECU - vacuum hose - MAP sensor itself Manual has procedure on testing all of these along with measurement standards. Most of time, it's vacuum-hose that got knocked loose or connector was unplugged when removing/installing petrol tank. Identify actual cause of problem through measuring and testing first. |
