Few new bike questions =D
Hi all,
Bought a f4i recently and I had a few quick questions on some maintenance and riding.
What do you use to wash the bike? Do you also use this for the seats.
I bought S100 recommended by the shop guy. Thoughts? Recommendations?
Where on the seat do you sit when riding (cornering, coasting, accelerating, etc..)? And what angle do you lean over your bike?
I usually am hugging against the tank, but when coasting I find this somewhat tiring on the arms over long periods so I try to sit further back and rest on the tank. Though I end up sliding up and down the seat when braking and the sort. Had a ninja 250 before this so I am somewhat used to upright if not mildly leaning.
I'm somewhat small 5'6" may be my problem. Not really sure.
What size is the default sprockets front and rear (how many teeth tooths.. whichever)?
Not sure if my speedo is spitting out a wrong number. I looked around the forum and read that error may be caused by installing different size sprockets to either front or rear. I know the previous owner changed the sprockets, but I'm not sure which size. Would like to know if i am going too slow or too fast on the freeways -.- .
Which rpm/speed do you switch gears in?
Looking at the manual it gives some speeds that you should switch down. I usually switch up after hitting 4-5k rpm and going down I just wing it with feel. Recommendations? Asking because I had to break quickly on one occasion and to assist my front and rear brakes I switched down gears. During this I heard some weird stuff going on to either my drive chain or back wheel. Felt like it was bunching up (if chain) or my wheel was just slipping. I am generally pretty relaxed so nothing much happened besides regaining control and stopping. O.O
What can I do to keep my bike in good condition if I don't have a garage to let it sleep in?
I bought a motorcycle cover, but I have a feeling this may not be enough. Anything anyone can recommend?
[IMG][/IMG]
Those are pretty much the questions that popped in my head after riding on the bike for a few days.
The bike really looks like a wasp/hornet/bee with a tank protector.
Thanks for any and all help, recommendations, and advice =]
-Chui
[IMG][/IMG]
-Chui
1: i use soap and water, i bought s100 for cleaning nasty crud when i first got her, she sat for 6 years. THEN i use honda polish, super awesome stuff.
2: i sit right behind the tank, and when going, you know, 120+ i'll scoot back and tuck, my current sprocket setup gets to 150 with a quickness but no higher. and i lean my bike over pretty far on roads i know very well.
3: 16/46, yeah 4.5krpm sounds like a good gear change with stock setup, the bike is going to be low on power at 3krpm so dont open the throttle below that. Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator this site is pretty straight forward. in 6th gear at 4000 rpm you should be going 48 mph. and during emergency braking pull the clutch in and don't use the rear brake, because chances are you will slow or lock the rear wheel up.
4: that cover is going to disintegrate within a year, if its at an apartment there isnt much except see if you can hide it under a stairwell. you could buy a car port type tent thing. i dunno much else, except those covers work but are crap in the elements.
You'll just have to clean and lube the chain more often, since the bike is exposed to moisture even if the cover keeps the rain off. You might get two or three winters out of a cover if you're lucky.
Again thanks for the input =]
Stomp Grip Traction Pads - Street Motorcycle - Motorcycle Superstore
Check those out... Makes it a lil easier till your legs get used to gripping the tank
