Fairing Install... %$#@ #$%@
You shouldn't need to drill it. Just use some needle nose pliers (I prefer a small flathead screwdriver) and pull the front of it through the back. Be careful not to tear/poke a hole in the rubber.
If I remember correctly he went with Delkevic fairings which is what I went with on my F4i and I did have to drill those holes ever so slightly bigger then use some muscle and put them in. Then once in and tightened down the rubber would expand and be all set.
Thanks guys! I ended up getting it done with a flat-head screwdriver... pushing them through little by little... Didn't have to drill the holes, but it would've probably helped make it a bit less of a headache.
Huge thanks to RDub for the fairing bolts you sent, they worked perfect!![Smile](https://cbrforum.com/forum/images/smilies/smile.gif)
...and here she is... slowly getting her up to par, really can't complain about a sub-$2k 03 F4i though![Smile](https://cbrforum.com/forum/images/smilies/smile.gif)
![](https://i113.photobucket.com/albums/n236/nrophoto/2011-02-19174044-2.jpg)
I ordered a cheap kit off Ebay a while back, but they didn't have any rubber nuts. I've been trying to tighten down regular nuts and bolts on the fairings, but they tend to vibrate out over time. What you've got sounds just like what I need
