F4i Starts, won't maintain idle FI light comes on and dies
Old 11-30-2017, 06:35 PM
Default F4i Starts, won't maintain idle FI light comes on and dies
Hey Guys,
Been a reader for a while and am after some advice. Bought a 2001 F4i a few months ago, I've had issue after issue with this thing, currently the bike starts but unless i'm giving it throttle it wont maintain idle and the FI light comes on and it shuts off. The green HISS light also comes on, but i forget if that normally comes on when the bike shuts off....
I replaced the FPR (was leaking fuel from the vacuum tube when i turned the key), but no improvement.
Currently suspecting maybe something electrical, but really have no idea.
I'd love to sort this myself, but am very tempted to take it somewhere. Any advice would be appreciated!
Old 12-02-2017, 01:13 AM
CaBaRet's Avatar
Hi , does the throttle adjustment **** not manage to hold the rpm, have you got the service manual
Old 12-02-2017, 02:43 AM
Correct, and the bike dies instantly, no bogging/struggle. And yeah I have the service manual.
Old 12-02-2017, 03:01 AM
CaBaRet's Avatar
Have you got any saved codes on the ECU
Old 12-05-2017, 06:20 AM
as in the FI error codes you get when you short the plug?, just did that before, i have the following:
8 (short)
9 (short)
1(long)- 1 (short)
1 (short)
So according to this:
A long blink = 10
A short blink = 1
CODES:
0 - bank angle sensor, ECM, PGM-FI fuse
1 - MAP sensor
2 - MAP sensor vacuum hoses, or sensor itself
7 - ECT sensor poorly connected or open circuit
8 - TP sensor, TP senspr wiring
9 - IAT sensor connection, or open wire
10 - Baro sensor, or connection, or wiring
11 - Vehicle speed sensor, or connection or wiring
12 - #1 injector connection, or faulty injector
13 - #2 injectior connection or faulty injector
14 - #1 connection or open/shorted circuit
15 - #2 connection or open/shorted circuit
18 - Cam pulse sensor, connection or loose sensor
19 - Ignition pulse sensor, connection or loose sensor
20 - faulty E-PROM in ECM.
I have issues with:
8 - TP sensor, TP sensor wiring
1 - MAP sensor
does this sound about right?, the bike is pretty much a converted stunt bike with a few extra electronic bits... jet ski kill switch, speedo healer
Thanks for replying, i'm pretty new to this, done relatively simple bike maintenance but keen to learn
Old 12-05-2017, 06:48 AM
CaBaRet's Avatar
Think what I'd do is reset the stored faults and look again what you have left, then you can get to grips with those, reset in the manual, then lets see what you got could be the TPS
Old 12-05-2017, 09:07 AM
74demon's Avatar
This would have been good to know in the first post.
Old 12-06-2017, 06:02 AM
i followed these instructions to reset, i should of been more thorough looking though the manual, but found these online:
1. Turn ignition off.
2. Short the service connector.
3. Turn ignition on.
4. Remove jumper wire from the service connector.
5. The MIL lights for five seconds. While the light is on short the connector again. If you successfully erase the memory the MIL will turn off and then start blinking.
Followed those, now when i jump the cable i only get a solid FI light, tired a few times... doesn't seem right, might try the process again tomorrow
Old 12-06-2017, 06:15 AM
CaBaRet's Avatar
Just got rid of the old faults that's all
Old 12-08-2017, 06:33 AM
ok cool, so now should i just check through the original faults?
Quick Reply: F4i Starts, won't maintain idle FI light comes on and dies
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
