F4i problems
F4i problems
Good after noon i'm having issues with my f4i that was recovered stolen. I made a video below explaining my issues. The fuel pump is priming good. I need help finding and routing vacuum lines my map sensor is not connected either not sure what vacuum hose connects it either. part 1 Click here update part 2 click still can't find vacuum hose for fuel pressure regulator
Oh ok so I have it wrong then the one I connected to map sensor goes to fuel pressure regulator and the open one missing hose is for the map sensor then.
Makes sense now the one I thought was for air box on left side goes to fpr and the open port missing hose is for map sensor. Ill try staring it later in the afternoon since issue before was not getting fuel, but pump is priming so I hope missing vacuum to fpr gives it fuel to fire up.
The following users liked this post:
favian (04-15-2020)
I got all vacuum hoses figured out now but I found that my idle screw adjuster was removed when bike was stolen too after removing throttle bodies. Im assuming that is why no fuel and start since they say it changes air/fuel mixture if im right.
