F4i phantom knock
Old 11-23-2017, 09:53 AM
paulbin's Avatar
Default F4i phantom knock
Hi guys my f4i has just started to make a very strange knock and I don't know where it's coming from.
It only happens at idle when you blip the throttle. Once you blip the throttle you can hear a single loud knock coming from the lower clutch area.
I have had the valves clearances checked, I also have a correctly adjusted manual CCT. My mechanic said it was the clutch basket, that looked in good condition, the damper springs were loose so we shimmed them and welded the basket back together.
After all this, the noise is still there, it rides well and has good power and I don't believe it to be bad bearings because it's not a constant noise.
As I said the noise only happens when it's warm and you blip the throttle quickly, you can hear a single knock.
Any ideas what I should check next?
Old 11-23-2017, 10:23 AM
CaBaRet's Avatar
Hi does this only happen at idle and when in neutral , or can it happen when in gear and the clutch oprerated
Old 11-23-2017, 04:15 PM
paulbin's Avatar
It happens at idle with and without the clutch operated. I haven't tried with a great selected yet
HenryM
1000F Videos
37
04-21-2013 02:12 AM
Fuegoblade
02-16-2011 06:45 PM
shakey
01-09-2011 03:44 AM
woo545
07-26-2008 12:31 AM
2002F4!
06-27-2007 05:28 PM
Quick Reply: F4i phantom knock
