F4i issue fuel pump/ lights
Old 04-18-2010, 10:51 PM
RideRed31B's Avatar
Default F4i issue fuel pump/ lights
turned off my 01 f4i for a quick stop today after a full day of riding and after a bout 2min of talk we was ready to go. well when i turned the key the needel jumped everything lite up and she cranked but wont start.....the fuel pump is not kicking on and the headlights are not comeing on but the gauges read the my highbeams are on still even if i turn them off......im thinking electrical but dont kno where to start ne one have the issue.
Old 04-18-2010, 10:57 PM
vangill's Avatar
July 2010 ROTM
bypass the bank angle sensor and see if that fixes it
Old 04-18-2010, 10:58 PM
RideRed31B's Avatar
how do i go about doing that?
Old 04-18-2010, 11:06 PM
teko1020's Avatar
I'd be checkin the wire harness under your left side fairing, just make sure that connector isn't loose. It could be the BAS but I don't see how that would effect your light switch.
Old 04-18-2010, 11:10 PM
RideRed31B's Avatar
i would be looking at the fuel pump but the light thing tells me its gota be something different are they connected in any way or on the same fuse??
Old 04-18-2010, 11:17 PM
teko1020's Avatar
The fuel pump will not prime with a defective BAS or the headlight harness unplugged. Turn the key on and stick your hand inbetween your gauges and your windshield and try wiggling the box you feel. But you'll probably have to take the upper fairing off and checking all the connections and making sure they are solid.
Old 04-18-2010, 11:45 PM
james_hale2's Avatar
i just had this problem last week to the "T". under the left air duct is the main headlight wiring harness plug. its got a big rubber sleve covering it. just unplug it and plug it back in a few times. if this works then you need to clean/fix the connections in there. mine was from changing my farings. when i plugged it back in it pushed one of the connectors out a little and didn't make contact(green wire to be exact). it caused the exact same issues.
Old 04-19-2010, 09:45 PM
RideRed31B's Avatar
wow that fixed it man, thats weird but thanx u saved me hours of bs
Old 04-20-2010, 08:47 AM
no problem. thats what this forum is for!
jondecker83
11-19-2014 05:14 PM
22opel
04-28-2010 06:07 PM
RideRed31B
04-20-2010 09:12 AM
600rr12
11-14-2008 12:32 PM
bushwiq1
05-08-2007 04:06 PM
Quick Reply: F4i issue fuel pump/ lights
