F4I dead all of a sudden (no lights,horn etc)
If it's like the F3, the main is built into the side of the starter-relay housing.
It is under the plug/cap. It's a 30amp. On my F3 it's just forward of the battery box.
Check for something similar on your bike, under the seat area. The fuses under the
fairing are for the lights, guages, various sub-systems.
Hope this helps, Ern
Take the seat off & look for the (+) positive battery terminal. Once you find it, follow it to the starter relay. There is a pink/red plug on top of it.
Remove the plug & replace the green 30a fuse. When you hooked the jumpers up incorrectly, you blew the fuse.
The other black fuse box is for other systems such as lighting, starting, fan..etc as stated above.
Have the battery charged & tested. Replace the fuse (& the battery in necessary) & you should be good to go.
WhiteHawk
05-30-2013 10:56 PM
