F4i custom map
I have a 2001 600 F4i with a yoshi RS-3 slip on with K&N filter. Anyone have a custom map that they are willing to share? It would be greatly appriciated. Not satisfied with Power commanders pre-loaded map and dont have money for custom map.
RE: F4i custom map
anyone have anything?
RE: F4i custom map
Bump.
I'm looking for the same map. |
RE: F4i custom map
i would download all the maps from the site. try them and see what works best. you can still fine tune it with the buttons if you prefer. and if you mess it up and it runs bad, reload your favorite map and try again. its a free suggestion and a possible solution to your problem. by the way, what exactly is it you dont like about your current map. it should be pretty well set up after the download. the only variable that i could see affecting it is altitude. and you can call the customer support and see what they recommend for a solution. my downloaded map seems to work fine but i have never dyno tuned it because im a cheap ass.
