F4i covered me in oil
ok so today I was riding to work like normal, when out of now where Im covered in oil and so is my f4i. I shut the bike down and got on the side of the highway safely. I didnt see where the all the oil came from. I put a little bit of oil back in just to see if the bike would turn over and it started right up just fine. Anyone have any ideas on this one.
I just changed the oil and filter last week and it has been running amazing until today.
ok guys thanks for the input, the oil came up from between the forks and tank and covered me head to toe. I took it to the stealership because i was about a block away from them. They took a look at it and discovered the o ring on the oil filter i had installed a week before was defective and had literately blow in half. so the just charged me the cost of an oil change and even cleaned the bike a little bit for me.
You know, I almost recommended that you look at your oil filter b/c you'd mentioned you'd just changed it. Then, I thought - no - he knows how to secure it properly. Don't often here of o-rings on oil filters doing that. Glad it wasn't anything more serious. :-)
