f4i clutch cable adjustment
Old Jun 4, 2017 | 03:09 PM
  #31
Tsouth937's Avatar
What's the cause I am having the issue as we speak
Old Jun 6, 2017 | 07:54 PM
  #32
xifer's Avatar
its because you need to push the lever arm farther past where it stops being able to be moved by your finger- from there the pressure plates actuate as the springs have too much tension for it to be moved by finger- then the cable and the lever should be tight
Old Jun 6, 2017 | 10:06 PM
  #33
SunBlue's Avatar
Thanks for coming back for the update I was dying of curiosity !!
Old Jan 25, 2020 | 08:09 AM
  #34
Tim French's Avatar
How was you able to push it farther?
Old Jan 25, 2020 | 12:33 PM
  #35
xifer's Avatar
its been a while but u need to think of it that if you can move it by your finger it is much too loose. the cable allows the pressure of the clutch springs to be moved with ease.
You need to adjust the bottom lock nuts until the clutch cover arm is no longer able to be moved by hand. this is the proper setting for the bottom, at the top end by the lever you just want a few millimeters play. you need play. you do not want to have 0 play.
youll be able to tell if you did it right if you have tension at your clutch lever. if it is able to be moved by hand at the bottom it wont ever be tight no matter how much u adjust the top cable. simple job once i got the concept but i just was confused by instructions online. hope this helps
roberino
Apr 7, 2017 07:02 PM
Turbulenz
May 17, 2010 09:08 PM
Turbulenz
May 16, 2010 08:11 PM
pixel 6
Oct 4, 2006 05:47 AM
roberino
Aug 10, 2006 04:24 AM
