f4i clutch cable adjustment
Old May 21, 2017 | 01:30 PM
xifer's Avatar
Default f4i clutch cable adjustment
Im having a hard time with my adjustment of my clutch cable and ive tried adjusting it all the way out on the engine side and all the other things i could of tried and lever still has no tension??
Old May 21, 2017 | 04:07 PM
74demon's Avatar
Is the cable broken?
Old May 21, 2017 | 06:24 PM
xifer's Avatar
No. also it is properly routed
Old May 21, 2017 | 06:51 PM
74demon's Avatar
The housing is routed. The cable could be broken inside. See if both ends move in tandem.
Old May 21, 2017 | 07:08 PM
xifer's Avatar
it's a brand new cable it's not broken I already tested it and the old one as well
Old May 22, 2017 | 12:10 AM
rfesu's Avatar
if you take the cable off, you can move the arm on the 'engine side' by hand and feel the engagement point. if you can't, then something has popped out. take the clutch cover off.
Old May 22, 2017 | 01:03 AM
xifer's Avatar
There is still tension on the spring so i thing im good in terms of engagement
Old May 22, 2017 | 11:08 PM
rfesu's Avatar
yeah but there's always tension on that spring, even if you have the cover off. if you pull on the arm, you should hit a spot where you can't pull it by hand anymore (this is the end of clutch freeplay)
Old May 23, 2017 | 05:10 AM
74demon's Avatar
Where did you get the new cable from? Maybe it's the wrong one.
Old May 23, 2017 | 09:12 AM
xifer's Avatar
Its the right cable, i ordered it from amazon a while back just been sitting
