f4i clutch cable adjustment
Im having a hard time with my adjustment of my clutch cable and ive tried adjusting it all the way out on the engine side and all the other things i could of tried and lever still has no tension??
Is the cable broken?
Originally Posted by 74demon
(Post 1304581)
The housing is routed. The cable could be broken inside. See if both ends move in tandem.
(Post 1304588)
if you take the cable off, you can move the arm on the 'engine side' by hand and feel the engagement point. if you can't, then something has popped out. take the clutch cover off.
Originally Posted by rfesu
(Post 1304595)
yeah but there's always tension on that spring, even if you have the cover off. if you pull on the arm, you should hit a spot where you can't pull it by hand anymore (this is the end of clutch freeplay)
Where did you get the new cable from? Maybe it's the wrong one.
(Post 1304643)
