F4i to 636 Clust Swap HELP!!!! Or Shoot Me Down
#31
Voltage alone won't tell you what you need. You'll also need to check amperage. Here are the equations you would need: http://en.wikipedia.org/wiki/Ohm%27s...rcuit_analysis
#32
#33
#35
as for power supply wont it all be 12V?
#36
#39
ya thats what i figured... im sure the 636 is as well... so figuring out the resistance figures i guess would be the key... i have my cluster up for sale if it sells ill get a 636 and try until then ill keep looking for figures and calculations to prove itll work without a hitch...
#40
Don't worry about the resistance. If it has a high resistance it will be a lower voltage. The question is the amp draw. The f4i doesn't draw more then amps on anything. Make sure the kawi only pulls less then 10 amps. Except the for the starting circuit which pulls a lil less then 30 amps
