f4i to 600rr tail
RE: f4i to 600rr tail
dont think its possible without alot of fab work. First off you would have to change the swingarm to a RR swingarm. The stock exhaust set-up on a f4i cannot bend up and around the stock swingarm. the RR exahust bends up just before the swingarm allowing the exhaust to contour to the shape of the undertail. I guess its possible to leave the stock exhaust but just using the RR tail. But then again i dont believe its a perfect match up.
click this link to see a little bit of a F4i with a RR tail. I just did it quick so the colors dont match up.
https://cbrforum.com/photo.asp?photo...Type=6&apage=1
Just look at every other tail conversion that has been done, regardless of the bike. It might be a bit more difficult if you intend to still use the seat for passengers, but it's still a pretty straightforward process. Make a new subframe.
As for the exhaust, I'd have to see some pictures of the F4i where the swingarm mounts. Possibly go before the mount, or wedge it in next to the shock. Or just go the easier route and go AROUND the outside of the swingarm like the undertail exhaust kits Wolf (Wolff, Wolfffffff, whatever) used to sell, then back underneath the subframe again. Just need a fabricator or some some bends & a welder if you're doing it yourself.
