F4i to 600rr subframe conversion?
Is it possible to put a 600rr subframe on an f4i? I love the way they look and saw that someone put one on an f3. thanks for the info.
the sub frame is a no go. You proly seen someone that modded the f3 subframe to use the rr tail. The rr subframe is cast, so theres no bending it etc.
he modded the f3 subframe ;)
good call i just looked at his build thread and saw that.................i have heard that the rr plastics will fit on an 01-03 f4i. Any input?
http://img260.imagevenue.com/img.php..._122_475lo.jpg
this guy just put a 1000rr plastic on the back unbolted and said it worked fine....could this work for an f4i? |
hard to tell in that pic, but it appears to be a stunter with a 12'oclock bar. It can be done but it isnt a simple bolton task. You will have to mod the subframe for it to look right. d3m3nt3d has a write up on here some where from when he did it giving some details of how.
anybody know where that thread is.....i cant find it
