F4 vs F4i cylinder head?
- Other than the vac ports for the carbs, is the F4 cylinder head any different than the F4i?
- Where is the F4i cam sensor located? - Can I swap the F4 single intake springs for the F4i dual intake springs? Thanks, Chris |
1 Attachment(s)
Found this pic on ebay. I take it that big "thing" with the wire sticking out of the head at the rear (which my F4 head does not have) is the cam sensor?
So in order to run the F4i (or RR) fuel injection I would have to convert to an F4i (or RR) cylinder head? Will the F4i computer run without the cam sensor (on cars they just default to batch fire instead of sequential)? |
No idea on the difference but yes you need to cam sensor to run the FI. Bikes and cars run very different injection setups, even still when a car looses a cam sensor and goes to batch firing the injectors thats called "limp mode" and the car runs horribly.
